Bedeutet es, dass ich mit Ubuntu oder OpenSuse in einer VM auch auf das Datei-System zugreifen kann? Und den Inhalt sogar ggf. verändern?Linux and OS X users should in most cases not need HFSExplorer for browsing file systems on devices, since there are native file system drivers available on those systems, but it seems to work fine if you need it. Linux users might find use for opening .dmg files.
$ aptitude show hfsplus
Package: hfsplus
State: not installed
Version: 1.0.4-12
Priority: optional
Section: otherosfs
Maintainer: Aurélien GÉRÔME <ag@roxor.cx>
Uncompressed Size: 242k
Depends: libc6 (>= 2.3.6-6), libhfsp0
Description: Tools to access HFS+ formatted volumes
HFS+ is a modernized version of Apple Computers HFS Filesystem. Nowadays, it is widely used with more
recent versions of MacOS. hfsplus consists of a library and a set of tools that allow access to HFS+
volumes.
$ /sbin/modinfo hfsplus
filename: /lib/modules/2.6.26-2-686/kernel/fs/hfsplus/hfsplus.ko
license: GPL
description: Extended Macintosh Filesystem
author: Brad Boyer
